Left side of steering wheel without lights?
My new car has no lights on the left side of the steering wheel. Everything works so it must be a fuse. But when I look at the owner's manual I cannot tell which fuse it might be.
I doubt it would be a fuse or nothing would work on that side. You likely have all bulbs burned out, or a previous owner removed the bulbs. When I got my car I had about 8 bulbs burned out on all areas of the dash.
May be a fuse issue but likely not. There are two distinct circuit going to the module. One powers engine start and the other relates to the audio controls. Turn the lights on and report back if all are off, audio (i.e. Mute), or just the start button. If you climb under the dash with a flashlight you can easily see these two connectors. The Start is the big white one (5 wire) while the smaller green one (6wire) is the audio. The starter switch has a lamp (1/4 turn bulb into side of start button) and another for the audio controls (1/4 turn bulb into module base). As J said the odds of loosing both bulbs are very low. If you do have a bulb out you can go here to get info and photos of the task:
Google "Qube Engineering"
Products
Qube LED Dash Controls
3rd or 4th tab at top is Support
Documentation
Audio Control
This is by far the best set of detailed instructions on dash electrical work procedures on the internet. Kudos to Art Trimbol (aka DJQube) at Qube engineering for his pioneering efforts on our wonderful cars!!
Utah
P.S. The circuit is powered indirectly through main gauge cluster. It is a 7.5 amp fuse in the under dash fuse/ relay box. This box is right by the hood release latch. The left has relays and the right has two rows of fuses. Fuse 5 is on the left ( inner) row and is 5th from the bottom. Also check fuse 25 which is the 3rd from the top on the right (outer) column.....also 7.5 Amp.
Products
Documentation
Audio Control
Utah
Products
Documentation
Audio Control
Utah
Products
Documentation
Audio Control
Utah
