To Lean?
Old 08-26-2004, 10:08 AM
clevelandscrap's Avatar
So if i buy the greddy emanage i should be good to go?
Old 08-26-2004, 10:54 AM
Hitman's Avatar
Check out this thread: My Lean APR
I am ditching my VAFC.
Old 08-26-2004, 02:26 PM
xviper's Avatar
Originally Posted by S2000_Europe,Aug 26 2004, 11:17 AM
the method is this
you can add fuel with the fuel preasure regulator and sustract fuel with the VAFC. With Comptech SC you can'tt Add fuel with the VAFC becasue interfires with the Electronic Signal Modifier.
with vortech I do not know, Where is Xviper????
Juan
I don't use a VAFC on my Vortech but I don't believe you can add fuel with it either. Most guys who need to add fuel do so with bigger injectors and an alternate ECU.
Old 08-26-2004, 03:19 PM
honda9krpm's Avatar
you can add fuel with the vafc on the vortech system
I've done it before.
However, there is a limit to the amount of fuel you can add as the VAFC basically increases the map sensor voltage. When this reach a certain level the ECU will cut off fuel. My max setting was 15%
13.3 at idle, constant throttle, decceleration or below 4krpm is not too bad. The stock vortech system only start to produce positive manifold pressure at around 4.5krpm
Gernby
11-08-2010 12:10 PM
rx7racer11
11-26-2004 11:46 AM
payyourtoll
04-30-2003 02:10 PM
Gernby
12-12-2002 01:10 PM
Austin_S2000
06-18-2002 07:21 AM
Quick Reply: To Lean?
