Leaky clutch cylinder
#22
Originally Posted by Jasonoff,Jul 19 2006, 07:10 AM
I took that line as you have to be an honest person to change at 12K intervals.
What interval do you use if you're not?
#24
You can replace the seals. Its not a hard job at all. a set of snap ring pliers and a 90 degree pick should be all you need. The install should only take about 1-1.5 hours. unless you stop for lunch in the middle. have a friend help you with the bleeding.
Using Dot 3 or 4 fluid is fine, as the clutch system will never see near the heat of the brake system. Bleeding the clutch fluid once a year is also a good idea to keep the seals happy.
#25
Can a leaky master cause difficult shifts? On mine it SEEMS clutch is fully disengaged based on the fact it nominally disengages not too far from the top. But could the clutch still be dragging?
#26
leo520
07-31-2014 04:56 PM
