Leaky clutch cylinder
I dont know what you call it but the cylinder inside the car where the clutch piston pushes in is leaking. Anyone had this problem? Must the entire thing be replaced or can you just take it off and put a new seal in there?
Originally Posted by xviper,Jul 17 2006, 09:43 AM
Sounds like you need a new master clutch cylinder. Just curious, how often has the fluid been changed over the life of the car?
If it has 52K miles on it I can almost guarantee you needs a new master. Possibly a new slave as well. The old fluid absorbs too much water collects too much gunk and ruins the seals and piston walls.
I found this out the hard way after changing the clutch. Both my master and slave slowly died with the higher pressure PP.
Originally Posted by jert534,Jul 17 2006, 08:32 PM
How much does a new slave and master cylinder run? I should change mine out in a few months.
