Leaking Top
Leaking Top
Hello, first time posting so please bare with me. I purchase a S2K 01' about 2 weeks ago, it was used with 45K on it. I got for a really good deal so I wasn't too worried about the top leaking air when up. Well now its bothering me and i've been searching the forum and haven't found any threads on how to fix this problem if its fixable at all. I am just hoping that I dont have to replace the top to fix it. It leaks air on the driverside corner of the top, and when im on the freeway it gets pretty noisy. Is there some where on the top that I could make some adjustments to make it tighter b/c when I pull down on the front of the top when its up it seems to make it tight and no noise until it gets loose again. Any advise on this is greatly appreciated.
Daniel.
Daniel.
Daniel.
Daniel.
Originally Posted by danrealestate,Jul 16 2004, 08:36 AM
Thanks for the info, do you happen to know where I can get the stricker from?
Daniel.
Daniel.
part 62 in the diagram
tell the dealer to look for the 2002 (updated) part in the "soft top frame" section.
or, order from here. it'll be cheaper.
http://www.hondaautomotiveparts.com./auto/...=SOFT+TOP+FRAME
they bolt right in, just take off the visors and pull the trim back a little. 2 bolts each.
