Leaking soft top
Leaking soft top
My soft top is leaking horribly between the body of the car and one of the metal brackets that supposedly seal it against the body. I'm not quite sure what these pieces are called, so I havent had any luck with search results.
Here's the area where it's leaking:
The bracket is a curved piece that contours the body of the car from the inside. Its bolted down with 3 10mm nuts. I've tried tightening it down but water still leaks in.
Does anyone have an idea of how to properly install that piece or fix this leak? Thanks in advance.
wsteun
12-09-2013 03:08 PM
