Leaking around VTEC solenoid
Hello everyone. I was changing my oil and noticed the sensor right by my VTEC solenoid is leaking oil. Does anyone know what I have to replace to get this to stop? I am going to post a picture as I get to my home computer.
If it's the sensor right below the Vtec solenoid, then that's the timing chain tensioner. I had a leak from the same spot and it turned out the 2 o rings that go around the TCT were bad. It's a 3$ fix if I remember right.
Are you talking about the sensor with the electrical connection? It's an o ring that fits inside the switch. Part number = 91319-PAA-A01
http://www.hondaautomotiveparts.com/...=CYLINDER+HEAD
You better hope it's #23 or #14, otherwise the you'll have to buy the entire solenoid assembly. There's a gasket for the top piece that isn't sold separately.
08s2000CRbackinblack
08-06-2012 01:30 PM
