LEAKING
LEAKING
Hey everyone, Newbie here
So it started raining here in CA and this is my first time in the rain with my S and I noticed this morning when I got in the car that it was leaking (few drops nothing major since it was in the rain all night) on the passenger side. I checked the window and door and it seems they were shut correctly, now I just got back from my lunch and I drove it (still raining) and after I shut the door then it starts leaking a few drops in the driver's side.
Is it normal? what can I do to prevent it? (Some pics below)
Thank you all
Thank you all
Received 1,716 Likes
Two things.
It is possible to adjust the side windows a number of ways (unlike ordinary auto side windows)
You can also hand lubricate the rubber seals, rub in well with your fingers, a pure silicone dielectric paste you can find at auto parts store (3M makes a good one) or plumbers grease at a big box hardware store. It is the same stuff as Shinitzu that Honda sells.
When is the last time you greased the seals?
(S2000 Owners Manual)
-- Chuck
Maintenance
Dust is the main cause of creaks or
other sounds coming from the
convertible top.
Regularly clean the body seals with
glass cleaner and a soft cloth. Do not
use a scraper or de-icing chemicals
to remove frost, snow, or ice from
the top or the rear window.
Every 3 to 6 months, depending on
how often the top is folded, rub a
thin film of Shin-Etsu Silicon Grease
(available from your dealer, P/N
08798-9013) onto the seals wherever
they touch the convertible top or
each other.
convertible top.
each other.
-- Chuck
Do what we suggest (once again the Shin Etsu is nothing but dielectric silicone grease) and rub in a thin film, a little goes a long way, and then see if the leak stops.
How would a thin film of shin etsu stop a water leak now? The lack of shin etsu probably caused cracks which resulted in the current leak. The shin etsu grease is used for prevention. I say inspect the seals for major cracks or gaps due to improper placement.
