Leak From Rear Diff Mount?
Old 04-24-2015, 04:37 AM
  #31
bgoetz's Avatar
Originally Posted by HarryD
Originally Posted by bgoetz' timestamp='1423971396' post='23506273
Just swapped all of mine. I went used and got very low mile ones from a very reputable member, except the driver rear. I got the driver rear used from a crappy member who screwed me and it had a tiny crack. I used a bunch of high strength rubber cement to fill it and am kinda thinking it won't last. The old one was totally toast, so I guess it can't get worse, but the whole swap is kinda a PITA, dropping the rear sway kinda sucks.
I just don't see how rubber cement will last on a fluid-filled mount. New OEM ones cost $75 each, no? Time is money, why cheap out when you can do it right the first time?
It didn't, 3 days of driving and it is toast
Old 04-24-2015, 03:26 PM
  #32
boyguan's Avatar
maybe wrap the exhaust there?
Old 04-29-2015, 04:54 AM
  #33
daMoufle's Avatar
Mine also have leaked ~2K miles ago on my AP1, I have got now a small vibration near 40 miles/hour.
Do I need to rush to change it ? Or I can wait a bit ? This can lead to which kind of issue ?
Old 06-19-2015, 08:34 AM
  #34
yellow_fever's Avatar
I was jacking the rear up this morning to see if I could locate the clunking sound when shifting from reverse to forward when fluid started leaking from the passenger side diff collar. I didn't know if was the diff collar till I found these threads. There is a crack on the aft end. I plan to replace both since the driver side is the one that usually goes. Is it Ok to drive to I get the parts in? Where is the best place to order from?
Old 06-19-2015, 11:54 AM
  #35
bgoetz's Avatar
Yes driving till you get them replaced is fine. Majestic Honda seems to have the best prices.
Old 06-19-2015, 12:20 PM
  #36
bgoetz's Avatar
Old 02-22-2016, 06:20 PM
  #37
Jtanaka's Avatar
Mine just recently leaked in the same place too, the driver rear. I was going to go innovative but decided to get OEM.
I found a video of how much OEM flexes. [media]https://www.youtube.com/watch?v=gMJJPqdCC2c[/media]
DOHC_Side
01-28-2016 08:28 AM
herecomesboost
04-02-2012 04:21 PM
s2000420
11-08-2007 04:47 AM
S2kGuy00
04-18-2007 08:56 AM
fin man
02-26-2005 06:39 AM
Quick Reply: Leak From Rear Diff Mount?
