Leak! need some advice from you experts.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
Originally Posted by trustafox' timestamp='1326928652' post='21329923
this is a photo of where leak is
![](https://i1056.photobucket.com/albums/t376/trustafox2/DSC06846.jpg)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Originally Posted by JFUSION' timestamp='1326928863' post='21329941
[quote name='trustafox' timestamp='1326928652' post='21329923']
[/quote]
hmmmm,
![confused.gif](https://www.s2ki.com/forums/images/smilies/confused.gif)
hmmmm,
well something has drained out of the lower sill area, it's not a fluid from any mechanical system from what I see in that pic.
[/quote]
this is the fluid, slight blue tinge. It appears to be reducing. May be its the washer reservoir and is dropping below the split?
[/quote]
![](https://i1056.photobucket.com/albums/t376/trustafox2/DSC06868.jpg)
Is your windshield washer reservoir bottle in that area, or are there some windshield washer hoses that run in that area ?. You may have a leak from the windshield washer fluid system from the bottle itself or some hoses. If the fluid leak ends up behind the side fender it will then drip out the drain hole in the body right in that spot Do you guys get temps running below freezing in your area ?, is there a chance the washer fluid bottle froze with water in it as opposed to proper washer fluid that is more freeze resistant ?, causing the bottle or hoses to split due to freezing. Over here we run washer fluid good to -40 degrees to be safe from freezing.
marks_lude
07-18-2009 08:42 PM
