Leak down and compression test
You are nearing the limit on # 1&4 and over on #2. The leak down numbers don't really point to HG to me, plus there are other more apparent signs of HG failure that will show up over any leak down test such as contaminated oil. If you heard no air coming from the exhaust or intake side then that's not valves. You did mention hearing air escape from the front valve cover breather? That would be piston rings.
Sounds like ring wear. I wouldn't worry about it too much, just keep driving until it gets worse. Chances are you will start going through some oil usage, and that will get to the point of ridiculous amounts and that's when you drop in a used long block.
So yeah that leaves you with the most cost effective and reliable used option, assuming you get a good one.
Well depends, it's hard to refinish the cylinders, but if the bores aren't damaged, then re-ringing them is all that's needed. However, my guess is the top end is the problem. If the guides are loose, half of the time you can just lap in new valves and that's that. Installing valve guides is tricky on these engines, the supertech guides have a little lip that makes it a little easier, as the install height is critical. I think that using guide inserts and reaming them to size would be a better choice if new valves doesn't do the trick. Of course if you're going to be replacing valves or guides you will be changing seals.
