Krank vents and oil leakage
#21
Greenlight and I were having a conversation about that a while ago but I can't find the post anywhere. He was the one that knew more of the specs that should be used in a pump and said he even had an extra one sitting around. I would try to message him and see if he'll comment help you out.
#22
Maybe this is something?
http://www.dragstuff.com/techarticles/vacuum-pumps.html
http://www.gzmotorsports.com/vacuum-pumps.html
I guess you could make a custom bracket & pulley and run the vacuum pump at the airco compressor position?
#23
A vacuum pump is the best way to go, but if you are only worried about dripping oil on the track and in the engine bay, just add a Jaz breather catch can. On my current engine project I'll be running one of those off the front KV. Here's a picture of the setup:
#24
Administrator
yes I have a catch can I'm gonna install. but having vacuum all the time in the krank case has its benefits too. I had assumed the kv's kept enuf vacuum in the crank case that it would say in neg pressure between corners.
-Ry
-Ry
#26
Administrator
yes I understand. thats why I was looking for more info about the pumps. Only ones I can find are big and belt driven which I don't want.
#27
Originally Posted by krazik,Apr 30 2007, 04:37 PM
because there's oil dripping out of it?
#29
Originally Posted by krazik,Apr 30 2007, 03:24 PM
I'll use some clean hoes to blow thru them..
I'll PM you a diagram so there is no evidence.
