KOYO RADIATOR HELP!
Member
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
Hello ![hello.gif](https://www.s2ki.com/forums/images/smilies/hello.gif)
I just recently got a Koyo Radiator, but I have a problem with it. THe Koyo radiator where you screw on the fan switch is different from the OEM and the fan switch rubber gasket isnt working properly and now I have a leaking problem. How did you solve the fan switch issue for the Koyo radiator?
thanks!
-Jeff
thanks!
-Jeff
I had the same problem with my Koyo radiator. I had noticed that the stock fan switch O-ring gasket was all smashed also. So the Mugen thermo fan switch with a new O-ring was tighten until it stopped leaking. It worked for me. (The O-ring did deform and appeared lopsided.)
If it didn't stop leaking I was going to pull it out and wrap the threads with teflon tape. But I did not have to go there.
Good luck.
Good luck.
Originally Posted by CrAzYNeSs,Oct 18 2005, 10:09 AM
BUMP - its been a while it seems fine now - anyone else have this issue?
