Koni Yellow shocks...
Did anyone try Koni Yellow for s2k?
how was it compare to coil-over?
and what spring that you have to go with the Koni Yellow?
You can use a stock spring, or a race spring. Ground control makes a collar for the Konis which will make them height adjustable, also they sell the kit with an Eibach spring I believe. This would be a good affordable setup in my opinion.
I have Koni yellows on my Civic SI and it's very nice, I like it alot. Definetly a better ride than stock, and handles great.
Chris
Chris
currently I have km/mm racing spring on my s2k...
do they work well with Koni shocks..
I am thinking about changing shocks only or go to coil-over.....but to me coil-over seems a bit wasting money if I dun go on track often right?
Currently I have stock suspension on my s2000, so take my advice with a grain of salt.
You should be able to run the kg/mm springs with the koni shock without a problem. The koni yellows are made tow ork with the stock springs or race springs. The kg/mm springs are meant to be stock replacments. Using that logic, they should work just fine, and that's how it works with my koni yellows on my Civic.
I believe that the S2000 koni yellows only have one perch for the springs, so if you used the kg/mm springs with the koni yellows then you would still maintain the same height as you currently have, but you'd have the stiffness adjustability.
On a completely seperate note, I can get you koni yellows for an awesome price! Let me know if you want a set.
Chris
Chris
02_s2k
03-06-2011 02:23 AM
