Koni Yellow perch adjustment.....
Was wondering if the perch was adjustable after it is installed on the car. Would I be able to change from the second perch to the first perch afterwards to raise it up if I needed to?
Also....if someone could post the part numbers for these, that would be greatly appreciated.
These have adjustable dampning too, correct?
unfortunately no. you're going have to take out it all out, change the perch setting and reinstall it. the only thing that is adjustable after its installed is the shock firmness(a knob you attach to the top of the shock body).
Interesting. That being said, say I have a set of Eibachs on right now, how much of a difference is it from the first perch to the second? Ride height wise. For example, would the second perch be stock shock level where-as the first is a notch lower?
Johnny
Johnny
