koni question
Old 12-23-2006, 04:43 PM
s2k_9000rpm's Avatar
Originally Posted by negcamber,Dec 23 2006, 04:35 PM
Yes...so long as you use the upper perch it will act like a OEM shock as far as ride height goes.
does this mean that when using it at OEM height (on high perch) it will be similar to the oem shock in terms of ride quality? i always thought the konis were an upgrade from oem.
Old 12-23-2006, 06:08 PM
negcamber's Avatar
To re-iterate:
So long as you use the upper perch it will act like a OEM shock as far as ride height goes.
The perch only effects ride height.
Old 12-23-2006, 08:35 PM
common reactor's Avatar
So it will be a stiffer ride?
Old 12-23-2006, 08:45 PM
negcamber's Avatar
It can be...Konis are adjustable for rebound (compression is pretty soft in my opinion).
Old 12-24-2006, 03:33 AM
SpitfireS's Avatar
negcamber Posted on Dec 24 2006, 06:45 AM
Compression is very soft, compared to OEM shocks.
When I had my OEM shocks out and felt how hard they were to compress I got worried that I would end up with a soft ride with the Koni's.
Because I could compress the Koni's very easily and the (old) OEM's were almost impossible to compress (I had to put all my weight on it)
IMO it turned out to be ok for me
Lets not forget : Koni = High Quality Dutch Product
With the adjustable rebound I could create a harder / firmer / bumpier ride then with OEM's (still using OEM springs)
I guess compression has less effect then rebound.
Chris@NLM
786
12-28-2015 10:04 PM
Nick.
04-28-2009 12:05 PM
notyourfriend
01-10-2007 09:45 AM
Dolemike
03-28-2005 09:45 AM
Quick Reply: koni question
