Koni adjusting question
So whats the trick in adjusting the left rear shock? Koni's adjust knob won't fit in that tight spot between the fuel line. I've tried needle nose and the conventional plyers. Any suggestions?
Yes...he made them and they work great!
Otherwise, you need to sacrifice one of your adjuster knobs and pull the keyhole out. It is pressed into the knob very tight and you will need to carefully cut it free. Then press the keyhole into a 3/8" socket (one that you can sacrifice as your new adj tool). With an extension on a 1/4" drive, you should have no problem reaching the adjustment key on the top of the shock.
Originally Posted by SpitfireS,Jul 31 2006, 02:04 AM
A set of these?
Originally Posted by SpitfireS,Jul 31 2006, 01:04 AM
A set of these?
Originally Posted by Slows2k,Jul 31 2006, 11:23 PM
On my KW's I installed the shock with the adjuster knob permanently installed. Just have to reach back and turn, No need to take the knob off.
Warren
