Knocking Noise (coming from the engine after warmed up) w/ Sound Clip
Old 11-07-2012, 01:52 PM
HastedS2K's Avatar
Originally Posted by jordanksartell
Originally Posted by apme123' timestamp='1352265661' post='22134654
sound like the main crank bearing took a shit to me
I don't think it's a main bearing. It'd be helpful to hear the motor revving a little bit when the sound is happening.
So i took a video after i read your reply.. From cold start i didn't hear any knock and after 3 mins being idle knocking noise starts to make noise so i started making this video. And so you guys know you will notice from minutes 1:43 to 2:40 knocking noise is fading and by 2:40 to 3:00 minutes its completely gone. Weird?!
Video with revving
Old 11-07-2012, 01:55 PM
MM3Kwolik's Avatar
If it goes away completely once warmed up fully you can pretty much eliminate any sort of bearing issue. This COULD be considered piston slap, but I'm not sure, because I've never heard it on an S2000 before. If it were bearings though, the sound wouldn't go away and would get far worse once warmed up.
Old 11-07-2012, 02:28 PM
HastedS2K's Avatar
Oh ok thank's for your response. I've just searched piston slap and i see its common on GM engines, correct me if im wrong.. Anyway, so do you guys think this knocking noise is harmful to the engine? I dont DD my car, i only use it on weekends and not driving it more than 10 miles. What do you guys think/advice?, should i still drive the car or not and bring it to a mechanic right away? I still drive it though. 2 weekends i think.
BTW this happened after we SEAFOAM & VALVE ADJUST.
Old 11-07-2012, 02:33 PM
MM3Kwolik's Avatar
PM Billman250 and ask his opinion (refer him to this thread). Chances are he has heard this before and can confirm my suspicions or tell you what he thinks.
Old 11-07-2012, 02:36 PM
HastedS2K's Avatar
Alright thank's a lot!
Old 11-07-2012, 04:55 PM
wpn52k's Avatar
sounds like a spun bearing to me sorry. drop the oil pan and the cover and see if theres any movement in the conrods or if its darker than the rest. it doesnt sound too bad so you could probably get away with just a crank grind, new bearings and conrod.
Old 11-08-2012, 11:10 AM
s2000maniac's Avatar
My AP1 makes the same noise. Once its warmed up it goes away. Thats pretty much normal.
Old 11-08-2012, 09:37 PM
Kami Speed's Avatar
Im with the guys, sounds like a spun bearing.
Good luck friend.
-Adam
Old 11-08-2012, 10:44 PM
well i dont know about you guys, but my AP1 has done it sine i bought it and that was 35,000 miles ago. If it was a spun bearing i think it would have showed up by now, not to mention two oil lab analysis says my engine is running pretty healthy. If it was a spun bearing I think it make the same noise even with a warm engine..
Old 11-09-2012, 10:00 AM
HastedS2K's Avatar
Ok so if you have a spun bearing will the car run funny or slower something like that? I never felt any difference ever since though.
Quick Reply: Knocking Noise (coming from the engine after warmed up) w/ Sound Clip
