knock sensor broke off in block...no bueno
Old 03-30-2024, 09:11 AM
Slowcrash_101's Avatar
It takes a 24mm socket. I don't know the thread diameter, but guessing based on torque spec ~24lb/ft, I'd say it's 8mm threads at most. I can't believe the service manual tells you to remove the intake manifold as step one of removing the knock sensor. Ain't nobody got time for that.
Old 03-30-2024, 09:28 AM
Alec Kelley's Avatar
I am going to have to take the intake manifold off because mine sheared off in the block like OP. He said he had to retap the threads was trying to figure out what thread depth and pitch was so I ensured I had the right tap on hand lol. Could not believe my eyes when the hex segment disassociated itself with the threaded end lol. Nonsense.
The following 2 users liked this post by Alec Kelley:
Slowcrash_101 (03-30-2024), windhund116 (03-30-2024)
Old 03-30-2024, 11:32 AM
Car Analogy's Avatar
Received 1,470 Likes on 1,086 Posts
Possibly aftermarket sensor that came apart like that?
Old 03-30-2024, 11:39 AM
My condolences, the IM is harder to remove than the cylinder head is on this car.
windhund116 (03-31-2024)
Old 03-30-2024, 03:13 PM
spider2k's Avatar
i did this once on someone else's car doing a phenolic gasket. ended up having to remove mine to give them so i had to do this three times in a week. its poopy and a good reason to leave that damn bracket out.
The following 2 users liked this post by spider2k:
noodels (03-30-2024), Slowcrash_101 (03-31-2024)
Old 03-31-2024, 09:27 AM
windhund116's Avatar
Received 1,540 Likes on 1,044 Posts
UGH!
All for a broken knock sensor. What a drag...
Old 04-01-2024, 06:48 AM
Community OrganizerMember (Premium)
jsenclosure's Avatar
Old thread, revived from the dead
Originally Posted by Plant_s2k
This is old but did you manage to remove this?I’m in the same situation thanks
Yeah, i got it out with an extractor. Not a fun job
Don't use an aftermarket sensor, that should be the takeaway here.
Never again, i learned my lesson 1- they don't work, 2-you'll end up with this mess when you go to remove the non working sensor
windhund116 (04-01-2024)
Old 04-01-2024, 10:18 AM
bad_driver's Avatar
out of curiousity, which aftermarket sensor did you go for? i went for an NTK and it seems to have died already
Old 04-01-2024, 10:36 AM
Sorry, to hear that.
But, thanks for posting this as a warning to all others. The genuine one may be expensive, but it probably is worth it --- considering the hassles of replacing a bad one.
RolanTHUNDER (04-03-2024)
Old 04-01-2024, 10:49 AM
someone revived this thread from 2013, my memory isn't that good lol
staylor725
11-02-2014 03:30 AM
Wannabes2k2k11
02-12-2014 07:11 PM
*spoon*
02-05-2006 11:28 PM
Quick Reply: knock sensor broke off in block...no bueno
