Knock :(
Knock :(
So I was driving my S at like 45 and started hearing a buzz, soon after i hear a knock and the engine dies. I go off to the side and try and start the car again and it does, but when i attempt to give it gas to move to the gas station it just dies. It sounds like its in the head, and i suspect that it was the valve retainers, but theres no CEL. and im stumped. Im planning on taking the head off tomorrow. And I pray its not too bad. sigh
Can you give any more detail? How low was the oil level when this occurred? How many miles on the engine? You heard a "buzz" followed by a single "knock" and then it just shut off? What makes you think the issue is valve retainers?
The oil was low, so I added more and after that I rode off and it happened. 156xxx. It wasn't a single knock. It was sequential knocking. I think it might be a valve hitting a piston but I don't know.
How low?
If it was low enough, you spun a bearing. Spun bearings will make a few loud knocks at cold morning startup, then go quiet, then come back as the engine warms.
I would pull the oil pan to check for a spun bearing before going through the labor of removing the head. If you were running low on oil, a spun bearing is quite likely as Bill mentioned.
I had a similiar noise. I thought it was in the head. I looked at retainers, scored cams, missing lma's, and nothing. Pulled the oil pan and no flakes. There was a little bit of play in the #4 rod on the crank. I replaced the rod bearing with a bigger bearing and the noise remained. Compression was fine too 215 all across. I pulled the motor apart and found the #4 cylinder was scored pretty bad near the top of the cylinder.
