Kill Switch
Kill Switch
Looking to install a kill switch and have done a search for what wire to splice into and haven't found what I would like.
I want it to be under the dash, easy to splice and access. If anyone knows where or which wire is best (I am thinking start button, but it is a little in accessible to splice or the key switch).
If you have a schematic that would be great, if you don't want to post it, just pm me.
Thanks
Thanks
Just get a pinout for the ECU, find the output signal for the fuel pump, snip, and extend the wires to the location you want the switch, mount the switch and that should do the trick.
Just my opinion but switches are prone to fail when they have continuous power running through them. I would go with a self energizing relay setup also known as a latching relay setup. I have had one in my civic for 4 years now with no problems.
Let me see if I can find you a picture of one.
http://www.ae92gts.com/ae92gts_antitheft.html
On this page there is a link to the word document with the kill switch diagram... I don't take any credit for anything on this page or diagram.... this is the exact setup I have except no hardwired bypass switch.
And if you don't know how a relay works....well then there's howstuffworks.com and some other diy websites that can show you....
Or maybe you shouldn't be installing a kill switch by yourself.
Thanks, but I just want to use a ground wire that I can leave open so the starter won't engage. It is pretty simple and everything will look like the car is ready to start, but the starter won't turn. Just my plan to slow a thief down and so that my wife leaves my toy alone!!!
