KIA 4.77 Gears are out of the diff!
1 Post
Originally posted by marcucci
Please do, and post back. I'd also appreciate it if you could take pics of the wear pattern...
Chris.
1 Post
My dial indicator measures in imperial units. At different points around the ring gear, I consistently measured 0.0050" to 0.0055" readings. That works out to 0.1270 mm to 0.1397 mm. This reading was taken from a Canadian 2001 Kia Sportage front diff with 6000 km (3728 miles) on it.
For reference, my Helm manual lists standard backlash for an '00-'03 S2000 at 0.09 mm to 0.11 mm (0.0035" to 0.0043").
Chris.
Chris.
1 Post
Well, I stand corrected about the rear Kia diff backlash. It's actually 0.0035-0.0043 inch (0.09-0.11 mm), just like our S2000 diff (I don't know how I read 0.008 - maybe I was breathing in too much degreaser yesterday...). I did get a reply on 4x4wire.com. A guy over there has a Kia service manual, and he says it doesn't say much about the front diff other than to use the assembly procedures for the rear diff. So I imagine the spec from Kia is the same. I have a feeling that neither Honda nor Kia spec'd that backlash, but the people who designed it (Mazda) did. It seems that same setting keeps showing up all over. Anyone want to check with the Miata guys (just to make sure) and see what they are using for their backlash? Now, I'm not say that's the right spec for our application, but I would like to get an understanding of where these numbers are coming from. Are they just some generic application spec?
Chris.
Chris.
It looks like a pretty significant amount of heel contact to me. Judging by the area where there is the least amount of dye, it looks like the peak of tooth contact is about 2/3 the way out on the tooth. The dye at the inner most portion of the tooth looks almost completely undisturbed. Which thrust washer did you use? If you try a different washer, please post pics and specs again.
1 Post
That's how I found the gears when I cracked open the diff from the wrecked Kia. I'm guessing this is how they wore from the factory. I haven't put these in the S2000 yet.
Something else I noticed, when rotated in the reverse direction, there appeared to be toe contact on the other side of each tooth, proportionally the same amount as the heel contact shown above. As I have never worked on a diff before, I'm not sure what that means. My service manual seems to suggest that both in the forward and reverse direction, both sides of each tooth should show the same pattern.
I also just realized that once taken out of this differential and put in the S2000 diff, this ring and pinion will be running in the reverse direction from what they were running in the Kia (the Kia is a front diff, not a rear diff). How might this effect anything?
Chris.
Chris.
