Keep getting cel light
Old 04-05-2011, 01:57 PM
S2000heart's Avatar
Originally Posted by JohnsS2000
gas cap seal migt have a TINY crack in it. mine did and the pressure loss in the tank caused a CEL. I have also heard of and known of a couple of people that had mechanically over revved engines that they had bent valves. A leakdown test revealed the issues as well as an attempt to adjust the valves finding cracked spring retainers
I took it to the shop, it I believe the valve is the problem
Old 04-06-2011, 07:10 PM
S2000heart's Avatar
Compression test came out fine.. Could it be timing chain?? Right now, when code is deleted.. It comes right back up..
Old 04-06-2011, 11:05 PM
1FastS2k's Avatar
Before you go and pull the head, pull your injectors and have them checked or just buy a low mileage set and throw them in. Replacing the injectors is a pretty quick and easy job. That's what mine turned out to be and there is a whole thread about it here somewhere.
Old 04-06-2011, 11:08 PM
1FastS2k's Avatar
Found the thread, click here for some good reading.
Old 04-07-2011, 01:35 PM
S2000heart's Avatar
I also thought it was injectors, but it wasn't injectors..
So we are going to check gas pressure today...
Hopefully it's not something big problem
Old 04-07-2011, 02:51 PM
exalto's Avatar
I had misfires on cylinders 1,2 & 3.
Crapped myself.
Turned out the plugs were working loose. Carbon build up on coil packs pointed the way. Was a huge relief.
Hope yours turns out to be so simple and cheap.
Old 04-07-2011, 03:21 PM
S2000heart's Avatar
Crapped myself.
thanks
Old 04-08-2011, 11:58 AM
jonathanyip343's Avatar
Any update ? Did u find anything ?
Old 04-08-2011, 12:52 PM
S2000heart's Avatar
I'm couldnt talk to the guy yet.. I'll let u know as soon as I find put
koreanbro
07-11-2015 06:43 PM
Frame_Runner__
05-19-2008 08:33 AM
w0rdie
08-02-2007 07:33 PM
EVAN_In_A_SPA
06-20-2006 02:16 PM
EVAN_In_A_SPA
06-19-2006 09:13 PM
Quick Reply: Keep getting cel light
