keep blowing a fuse
Originally Posted by FOSCshadow,May 23 2006, 04:49 PM
it also had the window in between the seats at one point.
it doesnt, you had said something about it being a hardtop at one point so i added that at one point it also had the windscreen, thats all. by any chance do you know which fuse the rear defrost would be powered under?
Sorry, I don't have my service manual with me, but you can have a look at the legend on your kick panel that shows all the fuses. That might give you a clue as to which one it might be.
Then they're on different circuits. You'll have to go in there and trace the wires to see what else is spliced into that brake light circuit. That circuit also supplies power to the ABS, Cruise Control, ECM and horn. Do those work when the brake lights fail?
brake light bulbs are fine, they work perfectly when the fuse isnt blown. if i cut the wire near the bulb of the aftermarket light will that solve the problem? or would i need to take ALL the wiring for that light out?
