K-Pro on an AP1 S2000. Need some help please
What is involved in running K-Pro on an AP1 S2000?
Is it OBD2 emissions compliant for inspection?
Any info would be amazing! Please!
Thanks
Thanks
the following items must be replaced before the S2000 K-Pro can be used. These parts are not supplied by Hondata and should be purchased from a Honda dealer.
Crank sensor 37500-PZX-003
Crank wheel 13622-PCX-013
TDC sensor 37510-PZX-003
TDC wheel 14112-PCX-003
Valve cover 12310-PCX-020
Drain plug washer (for PCV valve) 94109-14000
PCV valve 17130-PCX-003
IAT sensor 37880-P05-A00 (not required, but stock IAT will read about 30 degrees hotter)
The approximate cost of these parts is $300-375.
Correct me if I'm wrong but it's not really OBDII compliant. It will respond to an OBD scanner, but it will respond as an Integra or something or other, not as an S2000.
i just need it to pass obd2 scanning in NH for inspections and it sounds like it will. the car shouldnt matter i believe...but ill ask around
thanks guys, that link is exactly what i needed.
