K&N S2000 FIPK Installation
#131
Have to agree, took a lot longer than I'm used to for intakes. Looking back now, the longest part was figuring out which hoses connected where so just keep that in mind before you start the install and it should cut a lot of time. The only thing I can't figure out now is where exactly to mount the brackets to in the bay?
#132
#136
Which brackets are you referring to? http://www.knfilters.com/instructions/63-3514_inst.pdf
#138
Just picked up a used one for my 05, but unfortunately it didn't come with the hoses for the air control valve vacuum hose, the air control solenoid vacuum hose, or the 1/4" hose for the intake manifold and underside of the throttle body, or the saddle bracket assembly.
I bought it like this with the majority of the components:
So I have a few questions:
1. If so, would these hoses from O'reily work?
http://www.oreillyauto.com/site/c/de...0932&ppt=C0222
http://www.autozone.com/autozone/acc...er=534815_0_0_
2. Is the Saddle bracket assembly necessary? Will the intake stay in place without it?
All help will be appreciated. And Thanks in advance.
#139
#140
