k&n fipk compatibility question
I bought a used k&n fipk from a member on here he had told me this was the 57 series and it would work for a 2003. I get it in the mail and it says its for 2005-2006 2.2L s2000 63-3514. Whats the differences between the two? Do I just need to sell this and get another one?
I would check the install instructions, I thought on the 06-07 you drilled an extra hole, plugged one, or something in between. Here are the links so you can compare:
FIPK 2000-2005
http://www.kandn.com/instructions/57-3514.pdf
FIPK 2006-2007
http://www.kandn.com/instructions/63-3514.pdf
FIPK 2000-2005
FIPK 2006-2007
see i think that the person before me drilled the hole cause they had 06 or 07 model. will i be totally replacing the hard lines with the hoses supplied from k&n that comes with the intake? also, when i pull the hose off closest to the radiator off the stock intake elbow do i need to pull out the gold sensor also or am i just going to connect that hose to the k&n intake elbow?
