Just replaced my retainers due to over-rev
Former Sponsor
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
I once overreved or thought I did. I caught it before it bounced off rev limiter or anything so believe I saved it. Never checked retainers since but it has been years and tens of thousands of miles since then.
Originally Posted by MikeyCB,Jun 11 2010, 09:09 AM
Did you catch it before you heard it bouncing off the rev limiter? you actually have a decent amount of time to catch your error if you're quick back on the clutch. It sounds as though you may have only let the clutch partially out before noticing your mistake, or the clutch slipped slightly (in your favor).
The rev limiter from my understanding is a fuel cutoff and no more.
There is no "rev-limiter" when you're dealing with mechanical overrev.
CourageOO7, it's entirely possible that you pressed the clutch before it grabbed fully. If you had fully engaged the clutch in 2nd at 90mph, that would have been ~12.5k rpm, which would have resulted in a catastrophic failure.
Originally Posted by SpitfireS,Jun 11 2010, 10:30 AM
CourageOO7 Posted on Jun 11 2010, 06:25 AM
Can you post pictures?
Especially of the slighty stretched one.
Please
Was this your first ever overrev?
Please
![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
There are many pictures of stretched/cracked retainers all over S2ki, fyi.
I was banging off the rev limiter while accelerating at the track in 3rd gear. I shifted to 2nd unintentionally (I've only shifted 3rd to 4th 2 billion times in my life).
However, this motor has endured so much abuse. I am almost emotionally attached to it. It just keeps going and going and going and going...hehe
I did pass a 911 GT3 at that event, though...
Originally Posted by dantediss,Jun 10 2010, 09:38 PM
I just adjusted my valves tonight..same boat as you..just quick question..when you adjusted your intake side did you do it at a number 8 ? just curious, cus im seeing other people say it should be 10?
