Just had my first issue (minor) with the Vortech S/C.
pretty intricate stuff as always Dave.
How did you originally stumble upon this problem ? oil leak in garage ? oil light coming on ?
sounds pretty dangerous stuff hearing OIL leak with our cars, as we all know our cars DRINK oil
Thanks for the info I'm just about to start my installation the kit should arrive to-morrow.
Do I need to "Teflon tape" all the threaded connections in the kit?
Is there any specific type of tape or is it all the same thickness etc?
Kevin
Kevin
Kevin
Kevin
Every single threaded fitting needs teflon even if its a flared end. Actually I had Vortech send me another 90 degree swivel and the matching end to try it but i think it will be the same.
Teflon tape is all the same you can get different thickness but no need, just make sure you dont touch the first 2 threads, this will prevent the teflon from going inside and making friends with the oil (or enemies for this matter)
Originally posted by kstokell Do I need to "Teflon tape" all the threaded connections in the kit?
Grrr...no problems with mine (knock on wood) and like a dork, I followed the instruction manual word for word. No teflon tape used here, but no leaks either....I guess I should expect them, eh?
1150 miles on the Vortech so far....
