Just did an ECU reset
So I followed the DIY ECU reset last night. Super quick and easy to do, makes me wonder why I hadn't done it before. I've owned my for a year and 8 months (46k miles
) and have never done the ECU reset.
Initial Thoughts:
Car idles much better, doesn't bog when I come to a stop as if the clutch wasn't fully engaged, and I feel like it runs a little better on the top end too.
Right after I followed the DIY, I went out to the highway in front of my apartment complex and did a few runs up to redline 1st-4th gear. Car was pulling really strong.
If you haven't done an ECU reset, I high recommend you do so. I'll probably do one every few months or before big road trips - oh, and before emissions testing as it cleared my check engine light (main reason I did it).
![vtec.gif](https://www.s2ki.com/forums/images/smilies/vtec.gif)
Initial Thoughts:
That means that at sometime you got at least one tankful of crappy gas and your ecu "learned" that gas. Unfortunately it always seems to learn how to cut power but never seems to learn to increase power when you put good gas back in.
![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
What CEL did you clear? just because it cleared the check engine light now doesnt mean it wont come back. And when you try to get your car inspected it will show that the emissions system is "not ready" and you wont be able to get the car inspected. The only way to get rid of the check engine light is to fix what is causing it to throw the code
Just have to get past this hurdle then I can get the pipe rewelded when I get my test pipe installed next week.
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Resetting the ECU doesn't do anything. The ecu constantly adjusts for your driving conditions. It doesn't learn for 15 minutes and then stop. If it got better, it will go back again. Something is dirty or defective.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
also the fact that he got results in his idle as well as bog while comming to stop proves at least in his case it helped.
Originally Posted by 4forall,May 10 2010, 09:47 AM
It does do somthing. It resets it to factory maps and settings. If you happen to get a bad tank of gas or a mod just doesnt agree and the car pulls timing and fuel it will stay in that detuned state unless reset. it does not have the ability to increase hp or anything like self tuning, it can only retard from factory standings. so if you were detuned for w/e reason it can be beneficial to reset it.
SgtB was correct in saying that resetting will not fix the problem for good, the problem most likely will return. I have seen this many times before just a FYI.
