just changed my transmission fluid......
i just got done changing my tranny fluid, i followed the diy thread only diffrence is i choose to go with redline mt-90 mtf instead of honda oem. i took it for a test drive it is smoother between gears but goin into gears it still feels clunky or notchy, my s is a 00 with 65,000, any ideas.
Meet up with some other s2k owners and see if their transmissions feel any better. The s2k tranny can feel clunky & notchy to folks used to indirect linkage gear shifts common in FWD cars.
it's different from car to car, miata people loves the Redline mtf, which i use in my miata with very good result.
after using the redline in my s, i knew it wasn't right granted the SAE weight is very similar.
try the OEM version2 mtf or GMSMFM
I've always noticed that with a fresh fluid change, the tranny was a bit notchy. It seems to smooth out after a couple hundred miles. Then starts to get notchy again after 8k miles or so. Just from my experience.
Did you try clutch TSB 02-046? After cleaning/lubing the mecha, it feels much smoother.
Read the jpgs here
https://www.s2ki.com/forums/index.php?showt...=0&#entry983307
Read the jpgs here
webdiva
41
05-31-2005 05:37 AM
