Just bought a 2000 S2k, what do I need to do?
So the car is pretty much new but I dont want to overlook anything. Is there some areas I need to look at? Here is what I see;
Tires are like new
Brakes are like new
Coolant has been done
Has new air filter
Needs oil change
I think it has the clutch buzz but I am not sure. If it does, will it do damage?
Should I change tranny fluid?
Rear Axle fluid?
The brake fluid and clutch fluid look dirty??
The top looks new, does anything need to be lubed??
Is there anything else I am missing?
Thanks for the info...
Tires are like new
Brakes are like new
Has new air filter
Needs oil change
Rear Axle fluid?
Change the oil
I probably wouldn't change the Diff/Trans fluid, still has plenty of life. But you could change the fluids to have a "baseline"
Clutch fluid could be flushed, that fluid gets dirty very quick!
Brake fluid is probably Okay...? Brake pads still probably have 90% life on them. 19k miles is nothing.
Replace the tires. With 19k miles and the car being 14+ years old, I doubt the tires have ever been replaced.
The tires were replaced because of cracking. Unfortunetly the owner put all seasons on it.
I am concerned about wearing out the top. Other than replace the bands, keep it clean and treated, what else can I do to protect it?
