jumping idle at cold start
Happens infrequently, but what's going on when I start the car (cold) and the idle jumps from 1 to 1.8 (back and forth) for a few seconds and then regulates itself?
Thanks
Thanks
I see this as a couple of possibilities.
You could have a "lazy" MAP sensor. Try the "MAP whack":
http://forums.s2ki.com/forums/showthread.p...threadid=209708
and ECU reset (this is the same as the CEL reset):
http://forums.s2ki.com/forums/showthread.p...threadid=183490
Also, your emissions control secondary air injection system might be having a bit of a brain fart. This only operates on cold starts. Some owners have reported this system needing some attention.
If your car is starting OK and running well, I wouldn't worry about this little glitch.
