JIC coilovers do need to be preloaded
#162
RT, That's what I'm sitting here thinking. So what if JIC decides to send you guys some new-fangled-optimized spring rate! Sounds like the rates are going to have to be so much higher that you'll need the dampers revalved as well.
It also bugs/scares the crap out of me that Kevin thinks it's OK to be running around on the bumpstops. If that's the case why have springs at all? Just make 9kg/mm bumpstops and run on those, great idea...
Really glad I went with Tein...
#166
Kevin's comment about voiding the warranty by preloading more than .25" (causing the damper to top out) got me thinking.
Question: How in the hell is it even possible to top out the damper? I know that when the S2000 suspension is fully unloaded (limited by A-arm travel) and I disconnect the Teins there is still another .5" or so of travel left in damper. Are the JIC dampers really that short on stroke?
#168
Former Sponsor
[QUOTE]Originally posted by JIC USA
[B]
This is exactly why I said it EFFECTIVELY changes the spring rate. I am not saying it actually changes the rate of the spring.
[B]
#170
Wow, Kevin is outright lying to you guys! On the 5-15-03 he says this:
Then, the very next day, 5-16-03:
In one day!?
I feel that we are shipping these with springs that are way too soft.
We are already shipping these with stiffer springs.
