JDM Pistons
Old 11-22-2004, 06:47 PM
learnerspermit's Avatar
Default JDM Pistons
Does anyone know much about them as far as gains compression etc? Aloso where can I pick some up at and about what price?
Thanx in advance
~Eric
Old 11-22-2004, 08:13 PM
mxt_77's Avatar
I doubt the JDM pistons do much, if anything, to increase compression. I believe the increase in compression in the JDM engines are due to the thinner head gasket.
Old 11-22-2004, 09:16 PM
mikegarrison's Avatar
Dude, you should have let him buy them, then come back and post how they gave him 7.2 RWHP on the dyno.
Old 11-22-2004, 09:39 PM
HBtoS2K's Avatar
Thanx in advance
~Eric
Hey what's up learnerspermit, I'm not sure but I think with the JDM pistons, you will get a 11.7 compression motor. Check out this link bro: http://asia.vtec.net/beystock/honda/s2000/...ower/index.html To be honest with you, if I were to tear apart the motor, I would go ahead and order a set of custom forged pistons. It's going to cost you more, but you'll get the compression you desire and you'll have a better overall piston to mess around with. Good luck.
Old 11-22-2004, 10:14 PM
RazorV3's Avatar
i think its a combination of both a thinner head gasket and the pistons. you can't gain .7 points in compression with only a thinner head gasket (compared to stock 11.0:1 c/r).
Old 11-22-2004, 10:16 PM
RazorV3's Avatar
Thanx in advance
~Eric
jdm s2000's can run with 11.7 compression because they have access to higher octane gasoline. you will have to run some kind of 'octane booster' at every fillup to combat the detonation problems you might have with higher compression. higher octane gasoline is more resistant to detonation.
Old 11-23-2004, 07:33 PM
Banned
S2Fire's Avatar
I think thats where the JDM S2000 extra 10 hp come from. So about 5-7whp maybe.
Old 11-23-2004, 08:49 PM
7-8 wheel on s2k n/a is not to bad. considering everything else for the n/a setup.
Old 11-23-2004, 08:51 PM
mikecl713's Avatar
would 93 octane be fine with the 11.7?
Old 11-23-2004, 09:31 PM
I would asume that it would be ok but to race you might as well mix some fuel. How much do these pistons run
Quick Reply: JDM Pistons
