is this the jdm honda oil filter?
Old 10-26-2006, 11:10 PM
RACER's Avatar
If you took the time to read the thread title, the thread starter asked if it was the jdm oil filter.
I merely said yes.
Old 10-28-2006, 10:01 PM
Steven2k's Avatar
Originally Posted by AusS2000,Oct 26 2006, 12:11 AM
Not if it's on properly. Unless you're some superhuman clamp handed beast.
I had one on tight once and no tool so I drilled a hole in the side and used a screwdriver to loosen it. Bit messy.
I now use the K&N HP-1004 which has a 1 inch nut on the end and a hole for safety wire.
safety wires for what? does the filter get loose?
Old 10-28-2006, 10:22 PM
jdmgpw04's Avatar
yea same question...
just bought the jdm honda dealer sells.. oh wait the usdm...
so yea, whats the purpose for that hole..... i saw that at pepboys.... once and its like 9 dollars.. i end up buying the jdm i mean usdm filter... which is the 15400-PCX-004 for 5 bucks .... cheaper and better which alot of you guys recommend to use the stock filter... am i correct....
Old 10-29-2006, 01:14 AM
RACER's Avatar
[QUOTE=Steven2k,Oct 28 2006, 11:01 PM]safety wires for what?
Old 10-30-2006, 03:12 AM
Dark's Avatar
geeze how tight are you guys putting the filter on?
I dont have a problem removing mine by hand when its time to change my oil, takes a hair of elbow grease but I dont need a tool or a srew driver.
Am I missing something here?
Old 10-30-2006, 06:31 AM
vtec9's Avatar
7/8th of a full turn after the gasket makes contact. If you can remove the filter by hand after 5,000 miles, you A) have gorilla arms, B) are not tightening the filter enough, C) have a problem with the threads.
Old 10-30-2006, 09:00 AM
Dark's Avatar
Originally Posted by vtec9,Oct 30 2006, 07:31 AM
... A) have gorilla arms, B) are not tightening the filter enough, C) have a problem with the threads.
not so much my left
i do 3k on dino oil, hand tight as mentioned. are you all lubing the gasket with oil?
Old 10-30-2006, 10:02 AM
RACER's Avatar
Do you check your oil filter in between oil changes?
Old 10-30-2006, 12:41 PM
Swiftoy's Avatar
I agree you are tightening to tight. There is no need to crank it all the way down. Tighten by hand and back off 1/4 turn or less. Ive been doing it this way for 25 years and never had a leak or problem otherwise.
Swiftoy
Old 10-30-2006, 01:15 PM
RACER's Avatar
Question for Swift: How long have you had your S2000?
Quick Reply: is this the jdm honda oil filter?
