jdm engine
Old 07-31-2011, 06:45 PM
motoracer90's Avatar
Default jdm engine
Anyone ever run a jdm f20c with a usdm s2000 ecu? my engine is trash and thinking about getting a jdm engine. Just need to pass pa emissions.
Old 07-31-2011, 09:40 PM
zbrewha863's Avatar
No you will most likely fail. JDM ECUs are not OBDII spec, and they don't run the air pump assembly the same way. I learned that when I bought that fiasco of a part Challenge made to eliminate the air pump.
Old 08-02-2011, 03:32 AM
has anyone tried this? one person says you have to swap some parts from old motor and some person says it wont work.
Old 08-02-2011, 06:25 AM
Billman250's Avatar
Received 1,395 Likes on 836 Posts
Id imagine it would work.
All your getting is the engine...use your intake manifold if needed.
Old 08-02-2011, 08:24 AM
zbrewha863's Avatar
Oh my bad, I got that backwards, I thought you were using a JDM ECU on a USDM engine. The only difference I know of with the JDM engine is that it has a higher compression ratio, so run good gas!
Old 08-02-2011, 01:30 PM
Billman250's Avatar
Maybe someone from japan can post the min octane rating for a JDM engine. I thought it was 97 octane.
Old 08-03-2011, 08:49 AM
anyone else have info?
Old 08-03-2011, 08:53 AM
zbrewha863's Avatar
USDM engine - 11:1 compression ratio
JDM engine - 11.7:1 compression ratio
With the USDM ECU, I feel that running premium 93 octane is fine. The ECU will just retard the timing when it senses knock, so it should be safe enough, but you have to keep in mind that you are running a half-a**ed setup, so it's not going to be perfect.
Old 08-03-2011, 08:57 AM
when you say not perfect, do you mean like throw check engine light on?
Old 08-03-2011, 03:21 PM
zeroptzero's Avatar
Received 3,763 Likes on 2,654 Posts
How about running a thicker head gasket, I think getting the compression ratio to 11.5 could be a good operating point.
Quick Reply: jdm engine
