JDM ECU HELP
![Thumbs down](https://www.s2ki.com/forums/images/icons/icon13.gif)
i recently bought a theft recoved s2000... since it didnt have an ecu i decided to go with a jdm ecu... yesterday i attempted to start the car for the first time. i would turn on the switch and the fuel pump wouldnt go on. so i went through the routine of how to check the fuel pump... everything works. except it still does not turn on. when i open the ignition switch.
i started the fuel pump manually... then i tried starting the car... still nothing...what i think is happening is the ecu is not working...
has anybody done a jdm ecu swap into their cars? my car is an ap1. is it a direct drop in?
I've tried mixing and matching ECU's on my car ( australian loom),
The US and AUS ecu's work fine. The JDM ones only work with a JDM engine loom. Not sure why, but if you got a wiring diagram you should be able to spot the difference. Its probably something simple.
BTW. If I swapped out a working ECU for a JDM and tried starting the car it would run for a few seconds on the residual fuel pressure then stall.
If you got your car cheap did that leave enough bikkies for an AEM?
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
The JDM PCM's fuel pump control is different. You need a US spec PCM or source JDM wiring diagrams to make it work.
Most of the JDM PCM's will have a speed limiter the US spec PCM doesn't have.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
![banghead.gif](https://www.s2ki.com/forums/images/smilies/banghead.gif)
Did a search and didn't find much other than JDM ecus don't have the immobilizer. I thought it'd work, but damn...
