it's cold....
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Originally Posted by s2k dre,Feb 8 2010, 12:59 PM
Check ur coolant level, and make sure the heater valve is fully opening.
There is a motorized valve on the pass side next to the hose that loops back into itself at the firewall. Have someone inside the car turn the temp control from cold to hot and ensure that the valve moves all the way. I had a problem with no heat and thought I had a coolant problem...turns out the heat shield from my turbo setup was blocking the valve from opening all the way
By not working, do you mean that the fan isn't blowing? Your description sounds like at 60mph, the incoming air is moving fast enough to move the heat (assuming recirculation is OFF).
