it's 10 o'clock. do you know where your oil filter is? (maint. tip inside)
Old 03-09-2004, 04:36 PM
  #21
davepk's Avatar
I think this is a problem with just about any filter. My '00 with OEM filter had an engine fire when the filter came loose and spit high pressure oil onto the header.
With the OEM filter there are 2 rings on the filter. The inner ring is a rubber O-Ring the outer ring is steel. The steel ring is meant to hold the rubber O-ring from blowing outward(radial blowout). As the filter loosens the gap between the steel ring and the face of the mounting plane widens. At some point the rubber O-ring squeezes thru the gap, breaking the seal and squirts high pressure oil all over the place. If your lucky like Voodoo_S2K it doesnt squirt onto a glowing hot header.
Old 03-09-2004, 05:45 PM
  #22
Voodoo_S2K's Avatar
Oh but it did. I have a nice little flame coming off my header. Luckly the group I was with managed to have some bottled water which I used to try and keep the flames down. The car that was following me said there was a point where he could not see my car through all of the smoke.
Old 03-09-2004, 06:24 PM
  #23
RACER's Avatar
[QUOTE]Originally posted by Voodoo_S2K
Old 03-10-2004, 06:20 AM
  #24
JDMpress's Avatar
Old 03-10-2004, 06:55 AM
  #25
Voodoo_S2K's Avatar
[QUOTE]Originally posted by JDMpress
Old 03-10-2004, 06:57 AM
  #26
heffergm's Avatar
For folks that are really worried about this and don't run the K&N filter with the handy bolt at the end to run safety wire from:
The trick I used from my racing days was to put a hose clamp around the filter, then run safety wire from the hose clamp. Actually, it's not much of a trick and more like a requirement (at least in motorcycle racing).
Old 03-10-2004, 06:58 AM
  #27
Voodoo_S2K's Avatar
Old 10-25-2004, 12:02 PM
  #28
WPS
WPS's Avatar
i just torque it down with a torque wrench and filter wrench to the oem spec.
takes out the guess work
Old 10-25-2004, 12:11 PM
  #29
nibble's Avatar
Just to bump this,
we had 2 incidents during our track event @ FC04. once caught fire and need new engine, I heard. The other was not as bad but it had ticking sound.
Old 10-25-2004, 01:13 PM
  #30
amartin's Avatar
I sprung a leak 1500 miles after my 15k service tune up.
Guess what?? My oil filter was about to fall off! SERIOUSLY close call.
Quick Reply: it's 10 o'clock. do you know where your oil filter is? (maint. tip inside)
