it's 10 o'clock. do you know where your oil filter is? (maint. tip inside)
Old 03-08-2004, 01:59 PM
AusS2000's Avatar
Glad to here there isn't a known problem with the K&N.
Old 03-08-2004, 02:30 PM
xviper's Avatar
[QUOTE]Originally posted by wortham
i've always heard it's not good to torque down the filter any tighter than hand tight.
Old 03-08-2004, 08:55 PM
Slows2k's Avatar
Here's the Mobil 1 M-105 oversize filter loosening thread:
http://forums.s2ki.com/forums/showthread.p...&threadid=84019
I fixed vjarnot's car from a loose M-105. it is not the correct filter, and has a good track record of blowing off. Vjarnot was lucky, his car didn't burn completely to the ground, a tow bill some fixed wiring, and a lot of cleaning were necessary.
Old 03-08-2004, 10:22 PM
Voodoo_S2K's Avatar
Did someone say K&N filter?
Old 03-08-2004, 11:07 PM
RACER's Avatar
I see you safety wired the filter so it stays tight, good deal.
Old 03-09-2004, 09:27 AM
jeffbrig's Avatar
I've always put the filter on as tight as I can reasonably get it by hand. This has worked for me on every car I've ever changed oil in. Any tighter and I don't know if I could get the thing off again.
Old 03-09-2004, 10:31 AM
wortham's Avatar
[QUOTE]Originally posted by jeffbrig
Old 03-09-2004, 12:31 PM
Voodoo_S2K's Avatar
Mine was tight and look what happened to it.
Old 03-09-2004, 12:33 PM
ninegrand's Avatar
^^ is what made me change AWAY from the Mobile 1 filter.
Old 03-09-2004, 01:51 PM
StrangeDaze's Avatar
From the full size version of that pic, it looks like the M1-105 filter. I think that is the oversized filter that was briefly popular here. I never liked that idea and stuck with what Mobil would say is the correct size filter for our car, the M1-104, and have had no problems with it loosening at all.
That said, I'll probably switch to the new Honda S2000-specific filter after I use up my last Mobil filter. They are cheap, compared to the Mobil, and readily available. The M1-104 is hard to find around here a lot of times.
Quick Reply: it's 10 o'clock. do you know where your oil filter is? (maint. tip inside)
