ITB's
ITB's
hey everybody, im not sure if this is supposed to be in here or not but i was just wondering what all would i need to run individual throttle bodies? i was looking at the toda itb's but wasnt sure if there was any other company making them. if yall could help i would appreciate it. thanx
TWM makes itb's for the s2k as well. http://www.twminduction.com/ThrottleBody/T...tleBody-FR.html
While your at it you may want that hondata intake manifold heatsheild. People disagree as to whether or not it makes power, but I personally believe that a lowered intake temp=more power. You may also want to check out this or last months issue of honda tuning which features a S with TWM itbs. Good luck.
it shouldnt be that hard......i cant see why someone hasnt figure out a piggy back system for the stock ecu to use with ITB's yet....
my old 88 m3 has ITB's stiock and its pretty simple....the ecu is very basic too
Hayward performance makes an ITB setup for our cars as well. Kingmotorsports.com use to sell them. I don't know if they still do. There are a few guys on here that had an ITB setup you should probably contact. Learnerspermit is one of them. I think after all is said and done with, you end up spending more for ITB's than you do for a supercharger or turbo.
IIRC, E30 M3 runs MAF instead of MAP. MAF doesn't have to deal with the unique MAP-to-air-flow characteristics from using MAP sensor and therefore requires a less sophisticated ECU. But then, the problem with using MAF for ITB is that MAF is located further upstream of the throttles plates. This will 1) delay response of air flow signal, 2) require a limited-size airbox/plenum between ITB and MAF that reduces instant throttle response from the ITB.
AWWHITE s2k
07-01-2012 06:05 PM
conboracing
12-09-2011 06:59 PM
