Issues with interior lights
Old 09-14-2011, 12:15 PM
T-Smac's Avatar
You are pretty much down to the Dome light switch. Either burnt up or internally stuck on OFF. If that isn't the problem, there's got to be two problems in the circuit.
Old 09-14-2011, 02:36 PM
S2_4SHOOR's Avatar
Schematic will help a lot. I'll keep a eye on this, I'll be able to help out on friday @ work. Sounds like something simple
Old 09-14-2011, 03:32 PM
T-Smac's Avatar
Ill post the writing diagrams I have tonight. But other than my previous posts, only 2 simultaneus problems could cause this
Old 09-15-2011, 01:58 PM
ckim715's Avatar
Interesting revelation: When it's wet out, at least the dome light buttons work. Still no response from the switch. Hmm. Must have a break in the circuit somewhere.
Old 09-15-2011, 04:48 PM
S2_4SHOOR's Avatar
I guess she likes it wet maybe get her wetter?
Old 10-21-2011, 05:10 AM
Dave04's Avatar
I'm having the same problem... I took apart the light assembly last night and it appears to be the 3 position switch causing the problem. It gets corroded and keeps the lights from working (which also prevents the keyless entry system from knowing I've opened a door and will lock it back after 30 seconds).
Luckily, you can disassemble the switch and clean the contacts, which fixed it for me. If need be, I'll try to take some picture of it tonight.
Someone beat me to it:
LINK
SheffieldSam
02-24-2015 11:55 AM
s2konroids
01-23-2010 09:22 AM
gabrielh
12-15-2009 04:47 PM
S2KNJ
07-14-2004 09:01 AM
lips2000.5
06-24-2004 07:05 PM
Quick Reply: Issues with interior lights
