Issues after Hondata Gasket Install
Old 05-27-2006, 10:55 AM
  #21
negcamber's Avatar
Originally Posted by Chiung,May 26 2006, 11:34 PM
Try pulling the fuse to the ECU (I think it's a 7.5A fuse marked "Back Up")
At a loss regarding your symptoms - your vac lines were fine IIRC. After about a dozen Hondata gasket installs, this is the first time I've heard of an erratic idle due to the gasket. Combined with the drop in performance and increase in fuel consumption, I'd venture to say it is not directly related to the gasket.
Try taking the VAFC out of the equation.
Thanks Chiung...
After searching the forum, I agree...I really doubt the kind of erratic idle and other symptoms I'm having is from the gasket. The kind of idle bouncing I'm seeing (1k to 2k) is not showing in any post where an IMG is involved nor is a perf drop or poor mileage.
Also, since the ambient temp these days is well above 90F, which means on the asphalt, intake air is probably close to 100-120F...I can't imagine the ECU seeing those temps from the IAT sensor would try to keep the car in start-up mode for long at all.
I'll pull the VAFC to see if that makes a difference, but the car was running normal and getting great mileage on the drive down to the mod day immediately prior to the gasket install. Then the issues appeared immediately after the install during the test drive and return trip after the mod day.
I'm wondering if I may have damaged something...an injector; the IAT sensor; or the IAC.
Old 05-27-2006, 07:28 PM
  #22
Slows2k's Avatar
Slow, how can I post these pics full size?
Pics uploaded to your S2ki gallery are automatically resized, If the photo was hosted off-site and linking to it is allowed by that site it "should" display in the orignal size.
Old 05-28-2006, 01:05 AM
  #23
RadioZero's Avatar
check for rips or splits on all your vacuum lines in and around your intake manifold.
Old 05-28-2006, 05:52 AM
  #24
wildcardtrd's Avatar
I remember that some of your sensors had to be mounted slightly different than mine because you had a different throttle body or something...particularly the one that had the zip tie or something. My guess is that one of your sensors are loose. I'd also make sure all the bolts are re-torqued. A small vaccuum leak anywhere around the manifold could potentially throw things off too. It's so odd that yours is having these issues. I haven't noticed any ill effects from mine yet, but then again, my car has nothing else done to it either....
Has that wierd drivetrain buzz come back that we experienced when you let me test drive your car??
...Thinking about it, all this crap started after I drove your car...that makes it all my fault
liquidtek
08-05-2016 01:48 PM
modMonkey
07-09-2013 02:00 AM
helloimsteve
02-06-2013 04:10 AM
Black Nugget
07-09-2010 05:41 AM
mice
04-25-2005 08:56 PM
Quick Reply: Issues after Hondata Gasket Install
