invidia test pipe noise?
hey just put on my invidia v3 and its really loud...now im thinking about getting the T1r test pipe, will this increase or decrease the noise level? and what else can I do to make the noise level just a little less without putting the silencers on
thanks
thanks
the only different in sound that you'll get between different test pipes is straight test pipes vs. resonated test pipes. the resonated one will be a little more quiet.
Originally Posted by EVAN&MONICA,Sep 22 2008, 09:36 PM
My test pipe made it louder but it also sounds better I think
When my test pipe was in there without silencers I thought I was going to loose my hearing ASAP.
so I put the cat back in and the sound wasn't quite as loud but I found it droned a bit more.
Cat with silencers is my DD set up and it's not loud at all.
I'm fairly new to car mods... Is a test pipe california legal? Like if you were to get pulled over by a cop, and he looks under and sees that you have a test pipe, would you get a fix it ticket? Also no cat is illegal correct?
Deception
03-19-2011 06:44 PM
