invidia exhaust help!
my dual invidia exhaust had a leak. got it jacked up and found out there is a gap between the pipe and the cat. looks like i didn't tighten the nuts enough and they all fell loose and gasket too. now i don't remember when i installed the invidia exhaust if i reused the OEM gasket or the one provided by invidia? because i can't find a spare one. none the less, where can i go bout replacing the gasket? i can just go to a hardware store to get the 3 nuts. but should i order a OEM gasket to work? or go get a invidia gasket? my friend said kragen sells gaskets you can cut out and fit to your car? any help appreciated.
lolls
04-25-2012 03:00 PM
