Intermittent Surging While In Vtec...
Old 07-23-2004, 10:55 AM
patuww's Avatar
I have had the same problem. The map whack seems to fix it. It does seem to return though every 4-5 months. For the record, the car is a daily driver with 15k miles and is VTEC'd very often.
Old 07-23-2004, 01:07 PM
Billman250's Avatar
Received 1,395 Likes on 836 Posts
Misfire counters all at zero, Slows2k...The newer Mastertech units will not accept the Honda software. If you can find one thats a little older, that hasn't been sent in for repairs (because they will automatically add the blocker software) it would work with the Honda software. So that would be nice to get ahold of as well
Old 07-23-2004, 01:09 PM
Billman250's Avatar
I'm gonna swap MAP's with a buddy and see if we can get the problem to jump to his car....Has anyone tried to disassemble the map and rectify this once and for all? I will do it if it can be done...
Old 07-23-2004, 02:19 PM
cdelena's Avatar
Just removing and reinstalling normally jars the sensor enough that the problem will go away for awhile. As I understand it the device just contains a pressure sensitive chip so once you hack it open there is little to see. I have seen half dozen incidents of missing at high throttle openings and it have been the MAP every time. I installed a new one on my car and it is the same as the old, needing a whack every year or so.
rasulrasulinho
06-24-2015 06:24 PM
brunodkid99
06-09-2007 07:03 AM
fakeplastictree
09-30-2004 03:32 PM
goneverything
07-08-2004 04:16 PM
WhiteS2k
05-03-2001 08:09 PM
Quick Reply: Intermittent Surging While In Vtec...
