intermittent power loss in the 6-9k range
Old 02-06-2003, 05:56 PM
lehighwiz's Avatar
i am experiencing some intermittent power loss some point after VTEC. The VTEC cam is engaging, but sometimes i can feel a tremendous hesitation (the engine is not governing). At first i thought that the clutch was slipping or the diff was messed up, but the revs do not jump up when i experience this. It happens in pretty much any gear, but it is most noticeable in 1-3rd gears. Has anyone else experienced this situation? Any suggestions?
thanks
Matt
EDIT: its much more prevalent at WOT.
Old 02-06-2003, 06:37 PM
Porsche518's Avatar
Sounds like misfire to me, do you have the cel on?
Old 02-06-2003, 07:49 PM
cdelena's Avatar
Do a search on MAP sensor. All the symptoms are consistent with that problem.
Old 02-06-2003, 10:01 PM
JamesB's Avatar
My car was doing that. I took it to the dealership, they said it was an air intake temp sensor. they replaced it and everything is fine now.
Old 02-07-2003, 02:21 AM
lehighwiz's Avatar
Thanks for your responses, there is no CEL. I am planning on taking the car to the dealership as soon as possible.
Matt
Old 02-07-2003, 07:12 AM
S2K
S2K's Avatar
Check the oil pressure switch. Mine was leaking and it was causing the car to run very sluggish between 6000-9000RPM as well. I think it was not sending the correct oil pressure to the VTEC solnoid. I replaced it and the power is back. I thought it was the clutch slipping as well, since there was a hesitation when I drop gears but the RPM would climb very slowly.
Old 02-07-2003, 08:18 AM
John MI blk/blk '01's Avatar
S2K,
Where is the oil pressure switch located. Did you have a CEL light come on? I have experienced this sluggishness and I have been to the dealer a couple of times and they say that everything is running fine They say no codes and vtec works fine. My problem seems to be intermittant though.
Thanks,
John
Old 02-07-2003, 08:46 AM
pellisS2k's Avatar
Strong Bad!
Old 02-07-2003, 08:54 AM
lehighwiz's Avatar
Originally posted by pellisS2k
Strong Bad!
thank god. someone else knows the power of strong bad...
http://www.homestarrunner.com
Matt
Old 02-07-2003, 09:41 AM
Lee355's Avatar
Either the MAP sensor or bad fuel. I've had the same thing happen to me and it turns out it was just a problem with fuel from a local station.
Quick Reply: intermittent power loss in the 6-9k range
