Intermitten Clanging Noise in First Gear and Turning
I started to notice this just yesterday and today I have been able to replicate the noise every once in a while.
The noise sounds like if you take a set of loose keys and dragged it on uneven ground. It's a light clang and I can't tell if it is front or rear.
It seems to occur when I'm in first gear most often and when I'm turning left. Typically in a slow crawl. Once I get into second it seems to go away, although I think I vaguely heard it once.
Within the last 500 miles I added coilovers, new wheels and have done an alignment. I just pulled all four wheels off this evening and added the right size hub centric rings. Did a visual check to see if everything was ok and didn't find anything. Brake pads look good, and I have heard the low pad screech before. This doesn't sound like that.
Any ideas or help? Car seems to drive fine, but it's an unsettling noise.
have you tried 3nd and at same speed as in 1st gear and turn ?
and u need to figured out if the noise is from front end or rear end.
just a note i fixed a frd of mine S who had the problem and i found his front end link was loose. same noise clanging
lower
03-23-2004 01:44 AM
