Interior Water Leak
Interior Water Leak
My car seems to be leaking water from the paasenger side when I accelerate or go around corners. It also sounds like theres rocks or something sliding in the lower dash. A/c related?
Check to make sure the A/C drain hose isn't clogged or crimped. The hose is at the very bottom of the A/C box pointed toward the firewall. Mine got all twisted and crimped by passengers kicking it, so it quit draining. That box can hold a LOT of water, so be carefull not to disconnect the hose, or it will drain onto your floor.
Thanks so much I went to look, and there was the hose all twisted up. Drained alot of water. Now I got to pick up the water that it kept leaking as i have a puddle on the floor. How will i know if my blower is dead?
